Brick wall, plastered, Plasterboard, OSB sheets. HA says remove OSB sheets = fire risk. OSB sheets glued. Removal = damage; instead bonding adhesive to put a skim coat over...Plasterboard
And foamPlasterboard
Shut up. No one creditable uses foam FFSAnd foam
FOAM
lol...I did actually. Construction adhesive foam and it sticks 'indestructible'...lol...that's why I am in trouble now to get also the OSB removed without damaging the wall back to brickwork.Shut up. No one creditable uses foam FFS
If I remove the OSB which is glued with foam I will consequently damage the underneath plasterboard sheets and would go back to bare brickwork and needed to start over again...that's because I didn't know that HA considered one wall in OSB as fire risk...I have learned my lesson...Your only option is to use plasterboard.
I assume you can't remove the osb as it's for a structural purpose?
Just tac it to the osb using drywall screws and your good to go.
Just plaster board over it. Don’t skim over the osbIf I remove the OSB which is glued with foam I will consequently damage the underneath plasterboard sheets and would go back to bare brickwork and needed to start over again...that's because I didn't know that HA considered one wall in OSB as fire risk...I have learned my lesson...
Why on earth did you stick osb over a previously plastered wall?If I remove the OSB which is glued with foam I will consequently damage the underneath plasterboard sheets and would go back to bare brickwork and needed to start over again...that's because I didn't know that HA considered one wall in OSB as fire risk...I have learned my lesson...
He knows his onions, he always uses FOAM when he's at work.Shut up. No one creditable uses foam FFS
