Remove Black Silicone Stains on Monocouche render?
castablanca747
Hi there,
I replaced at outdoor socket at home recently and I wasn’t as careful as I should have been with the Black Silicone sealantI used to seal the gap against the wall. I’ve made a bit of a mess cleaning out the squeeze out which has since dried onto the Monocouche render. I’ve tried using a bit of diesel to clean off but suspect the pigment has gotten into the pours of the render? Any advice for removing?
Many Thanks,
Yep, diesel has always been the first choice of cleaner for siliconing. My customers love the fresh and zingy smell it leaves.
You can buy a handy litre bottle from most outlets.
Always use clear silicon when you have 2 contrasting colours, unless you’re an ace with the silicony like Chrispy.
CHD.com/use clear/unless an ace/like chrispy/not diesel/unless you’re a farmer
If diesel isn't working what's the best way to remove dried black silicone sealant from Monocouche render without damaging it?
This could be a good solution for this, Thank You
Pride Thank You GIF by OttawaRecCulture
