NastyRhythm
Hi all
Just after some advice. I have a breeze block shed that I would like to render using Weber ocr.
Weber advised me to used Rendaid first at 3mm thickness, then press in some mesh and stipple roll it and let set
Then apply the ocr as required
Could I use bond it pre grit instead of rendaid? or should I be using mesh and Rendaid instead? Is the mesh absolutely necessary?
This is just a diy project so apologies in advance if I have anything wrong
