Bloody heat!!!
Was geared up to top coat the front of my new build porch on Monday gone following arrival back from France. I thought it was the only day before the temperature went skyward.
I WAS WRONG. It was going off faster than I could rub it up. Should've have done one cheek at a time,what a plonker I am.
Now it looks shi.e. The two sides and top are fine, done in cooler weather.
Both coats were sprayed on with Refina render gun so scratch coat sprayed onto full mesh tacked to thermalite block and left for a week. Top coat no mesh, 15mm plastic beads.
Mix was 5 plastering sand 1 lime and 1 cement and both coats hosed down before starting.
Must I hack it off and if so will it take the scratch and mesh with it and also the block?
Or could I paint with Hi Build and float that off to a smooth finish then lightly dry sponge?
Abuse from pros greatly appreciated:}
