Render finish ?
Seabream95
Hi all guna be patching some render in and just wondered does anyone know how to achieve this finish have looked all over the internet and can't seem to find anything similar it looks to me like a wet mix has just been like flicked on after the floating sponging process thanks fornure advice
Render finish ?
Hard to patch up unusual textures, Never looks good , just like trying to patch artex you will always see where it’s been patched , If it’s not too much of a larger area and the existing is sound I’d brush and scrape the existing painted area with a wire brush, Fill out the block work, Rend aid it and put a tight coat over the lot and then re tyrolean or sprayed sand and cement the whole area, only way to get it looking something like decent, Or hack the lot off and re do the lot
