sandyblocks
Need help have a roughcast house (with largish pebbles) unpainted render in poor state, it is cracked and hollow to the knock in places. Would knock it all off and get redone but the cement blocks underneath don't like to be disturbed. They are made of a high proportion of aggregate. (just had to rebuild rear elevation as block was disturbed!) The cement block is stable unless drilled with SDS or hit hard when it is friable and just crumbles away. Have had a few suggestions, use really light hand tools to remove very loose and then trying to go over the rest.
Is this okay to do and if so how? Have had various suggestions including attaching a mesh (but worried may struggle to get a fixing without disturbing cement block). Or rendaid then scratch coat before top coat.
Can't afford to take risk with knocking off as if this disturbs block no money to rebuild other eleveation, and don't fancy the house falling down!
Any products, suggestions, experience would be really greatly appreciated.
