what is the condition of the render now that it has being sand blasted ? what finish do you require ?
Twhat is the condition of the render now that it has being sand blasted ? what finish do you require ?
Thanks I’ll have a lookRasolite might be a good option
Thanks. Just had a look at Silicate system as well as Rasolite.Silicone bucket coat would be ideal with mesh
Thanks, what did you use to finish the parex base coat? I think we might have to look at sponge finish insteadwe have just recently completed a render over a sand and cement render.
we choose Parex parinter renovating base coat,with mesh. lovely material to hand apply. the only renders that i know off that is a stainless trowel finish is Alumsac coloured render. M R also have a trowel finish render but i was told that it is Alumsac that has been rebaged.
Ok thanks for advise. The base coat looks good option. Plenty of choice out there. Cost is also a factor with the volume. Cheerswe put a scratcher over the base coat. as we had some bags of mono 1.5 grit in stock that we wanted to sell, we applied a very thin coat of mono on and finished it off with an acrylic plastic trowel. this gave a finish similar to an acrylic render trowel finish.
