Render query on new build
Matt_Lincs
Hi,
I hope someone could give some guidance.
Our new build has been rendered and I’m not pleased with the finish. There is a horizontal line that goes around the house. I’ve assumed this is where the builder’s boards meet.
How can this be remedied?
We also have render all over the timber window frames. Is there something that can be applied to remove render from window frames, sills, soffits etc?
Thanks in advance.
  • Render query on new build
Hi,
Thanks in advance.
That actually looks more like a deliberate joint?
Definitely a deliberate joint as for why you would have to see it when been done was there scaffolding in the way was everything in and ready it should not have been done but sometimes theses things do happen
Can it be rendered over to cover it up?
Some clowns get this on ewi @ board join
It’s a stop of sorts @looks different shade (@could be lighting)
No silicone seal around those cills & heads either .
Covered over yea but where do u start and where do u stop
it can but you need to re do the area in question top to bottom otherwise your going to try patch it and that is going to look way worse it is a pity they did what they did have you talked to the builder see what he says
