dogman
I am looking for some professional advice (if possible)
I am starting a self build that is a passive timber frame which is counter battened and then clad with a cement based render board similar to Knauf Aquapanel and then a thin coat render( not part of this question yet)
A question about how the cavity between the cement board and frame has been asked that i cannot find a answer on any of the manufacturers pages.
The issue is if you need a dpc and weep holes above windows on this sort of build.
Knauf shown above does not show or mention one. The cavity will be vented at the bottom and top of the wall as normal
