rendering on marine ply
malo
Before applying rib lath can i use sbr or is there something out there for the job,all help most appreciated.
Welcome to the forum, do a search there is loads of info on subject, many differing opinions , just gleen what you like from the info provided, and don't forget the thankyou button
Use a thin coat system
......onto a proper Render Carrier Board - Not Marine ply.... (thin coat that is....)
What is the project / application / structure? What finish does the client want?
As Warrior has said - search the forum, there are lots of opinions and answers...... but if you give a bit more info, you will get a more specific reply.
BTW - Welcome to the forum! Enjoy...........
Stucco finish,the builder has put marine ply on,with breathable felt underneath,thanxs for the welcome fella's
