Hi guys
I'm new one here (first post) and have been looking into rendering systems for our house. We're rebuilding a 1950's bungalow with solid walls so most is coming down, but some is staying due to budget constraints.
The existing walls will be externally insulated with Kooltherm boards bonded and fixed directly to brickwork. The new build part will be constructed out of blocks to keep costs down. New wall area is about 150sqm and existing is 50sqm. Property will be a 1.5 storey house when finished and most walls will be 2.4m high apart from one section which is approx 3m (about 40sqm with a chimney) and two gable ends one 5.5m high the other 6m high.
I've searched for a while and can't get a clear answer i.e. how much each system would likely cost per sqm as there is so much variation out there! What is a reasonable cost to expect per sqm for this kind of project for both a monocouche and a sand and cement mix, with mesh/fibres to minimise cracking? Based in North Bedfordshire (nr Milton Keynes & Northampton).
Also, what blocks are best for the external cavity leaf for rendering onto?
Thanks in advance,
Jon
Thanks in advance,
Jon
