Hi all,
I'm new to this forum & just lost my first new post, I registered, then went direct to new thread/message, finished message to post, but got slung back to login, my message lost. Oh well, I'll keep this second one brief.
I'm in the process of preparing plans for a new build timber frame house in South Devon. It's an open panel system, 38x140mm cls/als studs with a render carrier-board external render finish. I've initially specified a system called a PRO-WALL from SAS, but have struggled getting quotes for this project, so my first question is:-
1) Can anyone recommend a similar system & applicator/company I can approach to get quotes from.
2) As just a single wall, i.e. not cavity walling, can anyone recommend a waterproof render or other below dpc level/soleplate level to cover over the new exposed masonry, this is a block & beam upper ground floor band of about 150mm tall with infill bl'wk. It's a split level property, with one elevation showing this 150mm tall strip below dpc level, then the side elevations transition downwards to a complete lower storey. This lower ground floor level is an existing rendered structure built of 450mm wide stonework with bl'wk piers forming a garage door entrance. So thinking of sand blasting the old painted render off first.
Ps. the property is right next to the beach, so any rendering type has to be quite hardy.
All the best,
Clayton.
All the best,
Clayton.
