Hi everyone
New to the plasterers form, so a warm hello to you all.
Currently re fitting a bathroom in a Victorian house, all the old lime render is off, now the old brickwork is not the best the wall could do with rendering to strengthen it. The bricks are porous.
My question is, can I just apply two coats of sand and cement render with waterproofer in the ratio of 4:1:1 straight on to the bricks. The first being the scratch coat and hence apply the second coat. My worry is will the cement render may not be compatible with the lime pointing of the brick work and hence may cause moisture issues in the future.
The original plan was to take the old render off and dot and dab with plasterboard and plaster over.
Sorry if this seems like a silly question, not a plasterer by trade.
Kind regards
Sunny.
Kind regards
Sunny.
