Brickwork is usually more porous so you can seal it, I think unibond make an external pva you can also use sbr with cement as a slurry, but on blocks your fine to render straight onto unless its durox or thermalites them you need to put riblathe on. As for beads common practice is to put a bellcast bead around the dpc line and above windows and just use external angles for the corners if the reveals are tight use stops plus use stop beads if you need to stop your render anywhere like between houses (stainless are better for external but very pricey)
