rendering
Pwillia2
Hi All
I'm hopeing to render an outside wall , so I need some advice
1) This is a brick wall however its inside a conservatory do I still need to render
2) what type of bead will I need , and does it depend on what type of plaster I use be it render or not .
You have 2 choices mate sand and cement it or bond it out ,if its just one wall i would just use pva and bonding . what do you need the bead for if its a corner use an angle bead set it before you start the wall
Hi All
if it inside and is a cavity wall then just use hardwall or bonding :) and skim on top
use the big beads not skim beads
No bother lad just one thing when you bond it straighten it off then devil float wait a day then skim with multi or whatever!
It can can be done on same day rated lad and iv done it myself in the past but have seen it blistering or hanging around all day, so would recommend leaving it a day especially if your not sure what your at!
