S a plastering
just wondering in the winter do you swap the mix around ie do you put waterproofer in the top coat instead of the scratch coat just so it pulls in quicker to rub up now its getting cold or is it a no no
evening all.. church... you really should think about putting a book together you'd make a mint passing on your useful tips.... what winter mix brand do you use/recommend.church said:I cut the waterproofer down by half the recomended dose in the scratch and use lime and wintamix in the top coat i also fill the drip beads out a little more when doing the scratch![]()
claw75 said:evening all.. church... you really should think about putting a book together you'd make a mint passing on your useful tips.... what winter mix brand do you use/recommend.church said:I cut the waterproofer down by half the recomended dose in the scratch and use lime and wintamix in the top coat i also fill the drip beads out a little more when doing the scratch![]()
church said:Yes its made by feb and its a accelerator/ frostproofer , it dosent speed things up dramatically but it seems to help you finish it in the daylightanother tip is never put on render later than 11 am if its not on before that time make sure you have lights ;D
Ditto :essexandy said:church said:Yes its made by feb and its a accelerator/ frostproofer , it dosent speed things up dramatically but it seems to help you finish it in the daylightanother tip is never put on render later than 11 am if its not on before that time make sure you have lights ;D
I've been caught out a few times and had to park the van with it's front wheels up on blocks to finish off in the dark :'(
No who ;D ;Dwarriorupnorth said:Did i mention who supplied the gear ???
pftmonojetman said:No who ;D ;Dwarriorupnorth said:Did i mention who supplied the gear ???
looks good mate,
warriorupnorth said:pftmonojetman said:No who ;D ;Dwarriorupnorth said:Did i mention who supplied the gear ???
looks good mate,
well seeing as your asking it was L&D at rotherham, nice blokes
napper83 said:warriorupnorth said:pftmonojetman said:No who ;D ;Dwarriorupnorth said:Did i mention who supplied the gear ???
looks good mate,
is this the same L&D ;D ;D
Lord & Downing
Unit J2 Aven Industrial Park,
Tickhill Road,
Maltby, Rotherham,
South Yorkshire
S66 7QR
Telephone: +44 (0)1709 818 614
Fascimile: +44 (0)1709 818 468
Sales / Purchase Orders: gemma@lordanddowning.co.uk
