rendering
How you going to wet the walls with a brush? we use water. But seriously if you don't know the answer to your own question then you shouldn't be doing the job....
Some people PVA, some people only wet the walls, some people say PVA is baaaaaad, others, f**k knows, this jobs full of a million different opinions and answers.
yeah diesel, just tell him that only rough fu.ckers or diyers use pva outside! go on, tell him! if not, shut the f**k up ::) ::)
and once again roofer, someone hasnt looked through previous threads and seen this questions been asked and answered a million times, not to mention theres 2 very detailed thread about all aspects of rendering done by essexandy and church.
Then point them in the right direction!
Hi Mate
rendering the same as plastering you have to beat the battle of the suction, you don't say if its on bricks or blocks etc. Thia is a good time of year for rendering not hot or cold if on brick give it a good soaking an hour before if on breeze you don't have to but you can, You can pva walls and render no problem I would use external pva you can also use plasprime which is good to control the suction.
Just one other thing mate don't make your mix 4-1 like most I see , why not go 6 sand 2 lime 1 cement
or 5-1 limebond cement really good tackle. put your waterproofer in the basecoat.
hope it it goes well mate
