Renovation plaster
Most branches don't stock it but can get it next day.
Use shitloads of it. What make is the travis one or is it on about dricoat which i wouldn't really class as a renovating plaster
Cheltenham branch stock limelite. There the only 1's I know that stock it.
The limelite version by Tarmac which Travis sell ,u can't get it now ,Tarmac had a bust up so parex step in and they are doing renovation plaster which emery a builders merchants are selling :baba::aburrido::bailando:
Is it quicker to use renovation plaster or something? A good waterpoofer will stop the passage of salts.
Why don't you just use sand and cement with waterproofer?
Cos it's a shite insulator and causes cold spots specially on external walls which leads to condensation issues
Sent from my D2303 using Tapatalk
Ok...Personally I always dry line external walls with insulation boards.
iv never used it before, with the renovation plaster am I right in saying you use it like you would putting thistle bonding on the walls (with out the pva) same goes for the finishing plaster? i.e lime finish plaster - multifinish ??
