Repairing plaster before wallpapering - Need Advice
RK1
Hi everyone. Removed old wallpaper from under window sill and had lumps of plaster fall out ( see pictures below). Need advice figuring out if I can get away with using Easyfill 60 or is the job a bit more serious?
  • Repairing plaster before wallpapering - Need Advice
Take the radiator off the wall and all the loose dead plaster that needs removing and replace with new.
Look around for a local, well recommended plasterer and it’s an easy fix.
Thanks - Found a good local plasterer and he did what you said. Took off radiator and dead plaster and replastered.
