Hi,
I need to level a ceiling before putting up the plasterboard. I‘ve seen two options.
first, and at the Moment the most logical is to cross batten the ceiling with with wooden battens to provide a level and flat surface for the board. I‘ll lose about an inch of height from the ceiling, but it’s an old house and the joists differ so much in level height, I’ll need to use a lot of shims and levelling.
second, use metal rb2 resilient bars as cross battens. I’ve only just discovered these, and don’t even know if it’s workable to set these up on this ceiling given the amount of levelling I need to do between each joist, and how the levelling would work as shims etc don’t appear to be useable? they are only 7mm in depth, so I’d not lose as much ceiling height.
the ceiling joists are 3x2 apart from one main 2x4 and I’ve no need to the acoustic benefits of the rb2 resilient bars.
my preferred option is number one, but I’d appreciate views on the use of resilient bars in this situation, in an old cottage with very un-level joists.
thanks
doogal
thanks
doogal
