Ritmo M, Webber Render settings?
So weve hand applied Webber for 12 months by hand and basically we invested in a Ritmo Last year to use with EWI and also Hardwall but the plastering firm have recently asked us to do the Webber Render.
We have the Ritmo M with Water Pump and also a Harrington Generator recommended to us by Les from PFT Northern
Spraying was an issue today, i had it on about 200 on the water and also the speed on 9 but the mix was really wet and also the machine was pushing 7.5/8 amps which i know should be around 6amp.
Can anyone recommend settings on the ritmo for the webber right constancy and water?
:RpS_angry:
What kind of r&s do you have and did you check the R&S for pressure? I have a L and sprayed W, chalk at 190 water speed 10 the clamped R&S was at 10 bar. Knacked at the end of the job though, only got 12 jobs out of it:RpS_angry:
Not 100% sure its dads machine ill ask him, well im getting 15 bar out of the R&S thats at speed 8 and 200 water coming around the 6amp mark seems thick enough just trial and error i think
