Ritmo slimline.
Swplastering
Hi all
Hi have been using machines for a good few years now and just recently got the new ritmo slimline and will be using it on Monday with Krend k1. Any pointers on start up and general running of the machine. Thanks.
I have a rough idea but not 100%.
Ok when u get the water pump connected to the Machine. Open the water tap on the side of the machine fill a bucket of water make sure all air is out of the machine. Then press the water button on the back of the machine. Make sure the water hose on the front of the machine is not Connected to the mixing chamber. Set the water setting 25 to 50 higher than u want so if u want 350 set it at 375. Connect water pipe to the mixing chamber, that's at the front of the machine. Press the water button fill water up to the top of the rotor head in the mixing chamber trun on the moter stop it. Press the water button fill up to the top of the rotor again. Now put in in 4 or 5 hands full of render as soon as u trun the moter on have someone putting the rest of the render in the Hopper. U can then fill the Hopper up. U can then turn on the moter cheek the render consistency. Put the water down or up on till its right. Make sure you wet the hose. Put it on the machine. Trun on moter on till then render comes out the end of the hose. Then put the gun on the hose Connect the air to the gun and the front of the machine. Plug in the compressor. Trun on the moter. Turn on the air on the gun off u go.
Good man,
you got there first otherwise could have saved you some typing mate
  • RITMO-L-Operating-and-cleaning-instructions-English.pdf
SAY AGAIN MATE?
