MrSquirrel
Hi folks,
Just had a roughcasting job done and looking for advice.
It’s a block retaining wall split into two sections. I'll be painting it to match the house.
It was done 4 days ago and the wet dash on one half is like powder, it comes off with the slightest touch. If I tried to paint it, it would all end up in the brush!
I’m no builder, and would consider myself a pretty competent DIY’er but have never done wet-dash. It looks to me like he hasn’t used enough cement with the dash on the bad section, or too much waterproofer. Probably a combination of the two, the more I think about it.
He mixed up a new batch of dash before doing the good section, and that seems to be fine. Possibly a little weak, but certainly acceptable.
To prove a point I mixed up my own dash (4 stones, 2 sand, 1 cement properly guaged) and threw it at an unseen portion of wall. After one day to cure my test patch is tougher than the rest of the wall after 4 days!
It’s annoying as the scratch and top coats were neat and tidy. Looks like he's just made a mistake on the first batch of dash.
The sand used was nice and clean, and i washed the stones in advance for him to get rid of any fines.
The good section:
The bad section:
Close up of bad section:
You can see the tiny grains of sand if you look close, not right at all. They should all be coated in cement. From a distance it looks fine.
Rub your fingers along it and it turns to this:
Clean grains of sand with no cement coating them, no wonder it has no strength.
More:
The bolster is sitting here waiting to strip the lot off! Roughcast is supposed to be bullet proof - not like this!
Cheers,
The good section:
The bad section:
More:
Cheers,
