Roughcast
plasterjfe
anyone into roughcast, this is one thing I never do but have been asked and ideally want to just spray a heavy finish from the pump onto the walls but just in case they insist I may well look a subbing it out, they are interested in a finish up the road from them, looks like 20 - 25mm casting stones - rounded pebbles not chippings and an all over colour of white off.
alternatively does anyone know where i can get a sample of the heavy sprayed mono/baserend from?
thanks lads
20-25mm stones :RpS_blink:, have used 15mm before and that was a pig of a job, good luck with it :RpS_thumbup:
I paul I know Les has been showing lads what to do with the heavy finishes. Wonder if he had a sample. I know one supplier who has a sample 1M x 1M but its fekin miles away from me Might av 2 gt Bri to bring it down :-(:RpS_thumbdn:
He did have a board outside the unit, don't know if it;s still there to be honest, give him a bell, or go on the forum
Not pebbledash dirtbill I suppose roughcast is a general term for heavy finishes, well its same idea but the stones are in a wet mix slurry and prob less frequent as pebbledash wich is usually the term used for dry dash as in spar etc wetdash roughcastings will be anything from granno slurry cast on up to 25mm/30mm limestones cast on mega heavy not very common and not used alot in this day and age, more common up in scotland i would say where coastal weather can be harsh
jonno. Roughcast is very popular down my way and can look good if done correctly. The best way to achieve it if you haven't done it before is a roughcast flicker gun. This will allow you to achieve the roughcast even texture without having to practice your technique on someones job.
The main thing i would do is ensure the base coat is very flat like if you were topping it with acrylic. Then as an example use K rend dash reciever for a butter coat and k rend roughcast mix to throw into it with your flicker gun. The roughcast mix is very important to get right (not too thick)
Done correctly this looks much better than a machine applied roughcast which looks like a heavy tyrolean. You can come to my gaff if you wanna make samples
SO it's a good old wetdash then, i feckin hate wetdash the cleaning up up is phenomonal not wanting to go odff topic but what tis the tecnique down south i usually
Mix all my cast first in 3-2-1 (with option for 1 bucket of lime for colour consistency) and spread on boards to "sour" then coat areas to be cast then leave till coat tightens enough to take a hit but not too soft where they will dissapear and not to hard where the cast will slide, then load mixer up with cast .... boom
rinse and repeat
Wetdash is very popular around here has been for lots of years however they are now starting to use the likes of k-rend, powerwall wet dash which i dont mind so much.
One of the old school roughcasters that worked along side us used to use a specially made caster which was like a coal shovel, his casting was top notch:RpS_scared:
we did some with 20mm an 10mm mixed together dry dashed on then flicked a sand an cement slurry over the top it come out mint but to wet dash that on might give problems seems very heavy an clumsy to me
its luck of the draw as to what experience you have under your belt. The boys who roughcast up mid wales take piss outa me cos i havent done much and am not as good as them, but then they came down here dashing :RpS_lol::RpS_lol: laying on 10mm thick and throwing the stones from miles away.
I had to sneak behind the boss scraping his super thick bed coat back not to make him look a cuntt.
would love to be as good as them at roughcast though
what gun are you on about gIANi ? flikr gun not a frekin tyro gun that wont shift the size of gear this beatch wants
it looks like a flicker gun but is made for roughcast, would be ok for a bit but get heavy. Prob best to get youre technique down like the boys. "dont be tickling nor nothing"
Done a bit of this roughcast using k-rend dash receiver and their bagged roughcast to top, It's knacky but once you get a feel for it easy enough, the place i did had to match existing buildings on a hospital complex and we were spot on after a bit of trial on sample boards, this was top half of building under rafters and soffits of course. On blockwork: masked up as usual, this is a messy undertaking, sprayed k-rend standard base coat just about the same as you would float s&c rubbed up with foat and nails for a key, nice stuff to float with , we used 10mm beads. Left it for a few days to cure/dry, we then sheated up underneath where brickwork was with blue lightwieght tarps, we only had two so sectioned accordingly, butter coat of dash reciever then dashed it after it tightened up, we seemed to use the same amount of bags to buttercoat as we used to dash. The buttercoat goes on like a heavey skim coat and then the messy stuff begins, dash has to be mixed and correct thickness for good results, we found when you scrape around the edge of tub with gauging trowel a sharp egde just visible and don't dash too thick, as i said it's knacky but you soon get the craic weighed up. I used a jug to put dash into bucket and the harling trowelled onto wall, The clean down process is quite quick if you have prepped correctly, results are satisfying and you can prep your next bay or do what you want, reveals are just rubbed up reciever. I was told in if you have to match a bigger wet dash aggregate to mix suitable stone with dash reciever and bobs your uncle and only the one product coloured product to buy, hope this helps someone sometime.
they would prob accept uncoloured and want the whole house painted afterwards to make the overall apearence nicer on the eye. problem is the client is looking at houses that have around 3 or four coats of paint over the years to keep them tip top that has taken the edge of the stones and blended the stones to the render more so, its something you will never get bang on this but we will see where it goes cheers lads
I am hoping to get an alternative sprayed product on the wall bloner lad fingers crozzed. I tried to find a finish similar to what she wants on net but could not find anywhere
Roughcast
Something close to this finish from a pump would do th trick
  • Roughcast
john you would get that sort of finish from standard white spar chipping. You can add as much as you need to a roughcast mix until you get the same result you want
there must be a heavy spray that will come close to this, I aint harlin no fekin stones me blones.... not in this life :RpS_cool:
