Bennyspreadsmore
hi guyss ive never used either but was just wondering whats better out of the refina plazziflex and s*p*r*lex, from what ive read they sound similar. currently have a few mts that have gone out of shape
s*p*r*lex 16 inch everytime
I used my s*p*r*lex today and thought it was poo and went back to my month old skimming trowel which was a lot better
for the last 3-4 months I have been using eze spat 600mm and 800mm on ceilings and walls (reskims mainly) and im very impressed to say the least, I've got both plastic blade and flexi blade and in my opinion there exactly the same as a s*p*r*lex trowel only bigger, same idea get over gear quicker and when its a touch softer than trowelling with a MT trowel ,only fault is going over it too quick can cause stripes, but that been said its all personnel choice (marmite).I like it and saves getting on stilts all time, but you still need to tidy ceiling lines with a trowel but that don't take long , I trowel up with a stainless s*p*r*lex and there is no difference in closing gear in between spat or trowel ,as a older spread I am enjoying the ease some of these gadgets are making my job , if you can finish with a MT trowel you will find it easier with a stainless s*p*r*lex and final flick with a plazzy ,thanks tpf for letting me see the light:RpS_thumbsup:
No mate none required ,the water I use is to clean angles and that's it , same as trowel but bigger , if it go's too firm 18 s*p*r*lex comes out to help catch up but that hasn't happened often only when I have put too much on or a lot of awkward areasDo u use water when u use the eze spat
I await your review on it windyI have the ss speedskim 600mm but not had the right job to try it on
I use the s*p*r*lex 14' I love it. I spray mpfinish have u used the eze spat on it.
