Why not mix your own as we all should still be doing, its 100% cheaper and your in control of what your using. The mix i use is 5-1 sharp sand to opc and 1 pint of sbr in every mix. When i mix i gauge my sand and cement in small builders buckets and 5-1 is a full mix. I also mix in a large tub (half a water barrel) with my mixing drill i don't bother with cement mixers. I use the same mix for the scratch coat and top coat if its good enough for weber its good enough for me!
Surely that'd take ages to mix like that, i tried mixxing sme in a groilioa tub before with my whisk, and it was a crap mix...You can always leave one in the mixer mixing to if useing a cement mixer..
every job i have used it on i have had shrinkage cracks .... millions of them, scared to use the stuff now mark!
Yeh but it aint.
