plasterjfe
Any screed knowledge here please. ie. best ratio - 3:1 or 4:1 etc. Best products readymix/sand n cement. Price rates? Any tips? I have a job lined up to lay a basement around 100m2
Doin one just the same in the mornin mate , it's just the same carry on ,just be carefull with the under floor heating , make sure the labourer don't go F*****g up the pipe work when they barrow in.plasterjfe said:good stuff there lads. so church you recon i can gang subbies in at around 5-6 notes and charge out around 11ish? just found out they6 are insulating the floor with kingspan and fitting underfloor heating to some sections? any further comments on that. the heating will be water and i recon 15mm pipe used. taa
so you only screed small cuboards then mixing by handRoofer2plasterer said:Screeding is a piece off P**S mate. gauge with buckets at 4:1 ratio, i prefer to mix with a board and shovel. Wet enough to make a ball in your hand but not leave any resadue on your palm (semi dry).
del said:so you only screed small cuboards then mixing by handRoofer2plasterer said:Screeding is a piece off P**S mate. gauge with buckets at 4:1 ratio, i prefer to mix with a board and shovel. Wet enough to make a ball in your hand but not leave any resadue on your palm (semi dry).![]()
