You don't use scrim cloth as a key
EML gives a mechanical key where backgrounds dont allow suction or adhesion if there was a high stress element involved also you would use a mesh coat after you had applied your EML the mesh will deal with the cracking the EML with the key or bridge.
IMO EML wont help at all with cracking if it wants to crack it will come straight through the EML
i always got told to use EML before re plastering old property,over cracks in the walls and internal corners,beit 8x4 sheets or 6" wide strips.
this was off the architects of clerk of works,the blokes who invent all these theories.
i also would of thought metal would of been stronger than the scrim they use:RpS_thumbup:
but,in any case,you are right,if a building wants to crack,it will crack,no amount of s**t will hold it togeather:RpS_scared:
I think there is a knowledge problem across the building industry, sharing info is not widespread. I kinda have to favour nvq quals on this side of things although some of th best spreads I have seen dont have nvq and some yunger lads with nvq still dont know much about products or chemichals they use ? beats me
:huh:
the problem i find with new ways,is some don't work.
this year i have had to go and knock off 2 houses(council) which had been over rendered using the scrim stuff and top coat,don't know which sort.they had blown of the substrate,so knocked off scrim stuff,then other old render,then re rendered.
i was talking to a old chap the other week about a load of over rendering they are doing up my way,sticking insulation over the old render,then rendering over with the scrim stuff,it looks a real good job,but the chap said "you watch,in 10years it will be blowing off like a old prostitute,becouse when water gets behind it,maybe a leaking roof,or gutter,it will soak the insulation,and eventually blow it".
going off what plasterers got taught at college years ago,off old timers,i kind of agree with this chap:RpS_thumbup:
but more work for plasterers in ten years(if not before)
the problems you mention above do exist but because the system has not been fitted properly either because of budget or poor workmanship in these cases i agree the system could fail and cause problems thats why i hate all the undercutting in this field the simple of it is if you cut corners on these systems you risk all the failings possible than if a system is done properly.
the new stuff IMO is superior than the old but i dont agree with any old tom dik or harry "chucking it up" because they think they are a plasterer and its easy. if a good tradesmen with the correct level of training is installing then it will outlast most render. only these people should be fitting it.
Most big drylining firms are now pricing external thermal packages because the M/C cant be bothered the split the package some of them will sub let to a proper fitter but most will just chuck skimmers or any old pole outside to make more money. these firms have hardly ever come across it before:RpS_scared::RpS_scared: and this is where it all goes wrong, render reps hand out approvals to these lot because they have big credit limits and the contracts. it will prob come back and bite them on the ar5e one day but hey its all about the money.
