Silicone over sand and cement
FreeD
Anyone do much silicone over OCR or K Rend General Purpose?
Anything to watch out for?
Yeah OCR. Much easier to work with OCR than the heavy polymer modded products. Needs a good coat of primer though as its got a lot of suction when dry. Works well for me (y)
Is OCR micro cracking an issue say if you use Weber? And when you say a good coat of primer do you mean 2? or 1 generous coat?
It does micro crack to be honest. Can't seem to stop it. Seems to be where there is the slightest bit of suction difference. Even with a mesh embedded. Or where it's gone on a bit heavier. Anyway a good 1 coat of primer works well. Don't be shy with it or water it down.
