It was always a three to one mix in the earlier days with a bit of pva added to the gauging mix (yes i know pva) but that could be replaced with some sbr, use ordinary cement if you don't want to run to the cost of white, but there are differing opinions to the way tyrol is made up, especially when you take into account the the next coat should always be weaker than the first rule
