D
Deleted member 29624
Guest
On my rental house I got a brick single skin utility which gets a bit mouldy sometimes....what would be the gest way to sort....would stud, cellotex, vapour barrier help?
Its got a vent....and goldtrowel didnt teach us damp preventionGoldtrowel could help . Don't be asking us pros.
It will help make sure you have a vent in the room.
f**k**g courser
I got some vapour barrier in the garage so do you think normal board is fine if I staple that up first...saves £3 per boardyes mate just use foil back boards
yesI got some vapour barrier in the garage so do you think normal board is fine if I staple that up first...saves £3 per board
I know mate, arseholes.....they did have a whole 6 weeks too, you'd think the should have been able to fit it in....i had the plastering nailed after a week so was just hanging around hung over and smoking too much for the rest of itThe c**ts
How come it took you so long?I know mate, arseholes.....they did have a whole 6 weeks too, you'd think the should have been able to fit it in....i had the plastering nailed after a week so was just hanging around hung over and smoking too much for the rest of it
