I would like some advice on skimming the small area in the photo.
I am not a plasterer but I have skimmed new plaster boarded areas before with acceptable results and also done dry lining
I have had problems in the past with obtaining a decent finish on old but sound surfaces though.
Having stripped the area in photo I foresee problems ahead!
There will be 2 different surfaces with different rates of absorption plus a painted surface and a thick covering of wallpaper glue.
I am seeking advice on the best way to prepare the surface evenly for skimming.
Should I first of all try to remove all the glue with sugar soap or does the glue actually help?
What should I build up the door area first to make it flat - would "one -coat" do?
Should I them cover the entire area with something like "Wickes ready mixed bonding agent" to provide even suction throughout and a stable surface.
I have a bag thistle board finish for skimming but should I use something else?
Any help and advice on these questions would much appreciated please.
