KNOCK THE WALLS DOWN STUD PERTITION AND PLASTERBOARD AND IF YOU WANT TO BE FUSSY YOU COULD INSULATE INBETWEEN STUD ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D
give it 2 coats of PVA let first coat set then plaster when second coat still tacky... you could also score the paint with stanley knife to give a bit more of a key
