Slow plaster set down
Andy g
I would like to mix up 3 or 4 bags at once because mixing up is a pain , so what can I put in mix that will work 100% please thankyou
h72645D65
Try some extra time additive.
4 bags in one mix is flipping hard work mind you.
You might find you can do more mixing up smaller amounts and rolling your sets. You said before you was only putting on 3-4 bags a day, you said 30-40 mtrs. You could easy double that by rolling your sets and not do yourself in in the process. Hope that helps a bit.
As your mixing it add a little spit!keeps it nice and creamy and gives you another half an hour on your set,called the saliva slurry mix!!you a good shot Andy g??do more greeting than a Christmas card you cuuuunntt!!!!!
