I do this works a treatHello did your first coat lookkinda like cartoon cheese by that I mean loads of holes all over it? Wen you apply second coat air bubbles get trapped in between these one solution flatten your 1st coats. On you final trowel roy utrif you still can see them put your trowel flat on the walls effected area and in a circular motionapply some pressure then trowel normally fingers crossd theyll go if not go have a fag then give a dry trowel
started skimming my all today prity pleased with it it apart from few wee bubbles . were have i went wroung is it on to thin and is sanding down the best wae to get rid
