why would you?
yeah it does spunk thats what mccarthy and stone use spunk but 16mm thick cause they wont use soundboard on topSand cement does the same
the floating has already done the jobiv used it on newbuilds on the partywalls prior to dot and dab etc love the stuf just slap it on ya can make some canny coin never put it on board though think it be ok over old floating though ,
Maybe if a party wall is already boarded and extra acoustic protection is needed.
Don't be silly, this is used as a parge coat to fill all voids left by rough subby brickies. ...as Mr Gibbo states( freind), sand cement just as good ( as Spunkster says)
Althoug the BG gear is recognised in robust construction details.
because the job is spec for boards not float and set if you can hear next doors telly turn yours up louderYeh that rite dannymac iv boarded and skimmed my own house and now iv moved in can hear next doors fukin telly all nite, and gibbo if the floatings aready done the job then why put it under board?
Only on weekends CJK:RpS_thumbsup: never used the stuff before so just wanted find out abit more about jeeeeeez
twitcher whats up with knocking on the door and asking if they mind turning it down.
Yeh wel I thought as much and that's the way I'm guna go in the bedrooms but the front room has some old run coving which I wanted to keep so boarded up to it, so was thinking tight coat of sound coat then skim but didn't know wot it was all about but guna av dig the axe out I fink and put ma mad face on![]()
I turned a job down last week the lady was complaining of noise from the neighbour and the only way I could think would be too soundproof every wall on the side of her house, under the stairs bathroom kitchen it would have been a nightmare, very expensive and I'd be gutted if it didn't worka tight skim of soundblock wont do anything because the noise will still transfer through the wall above your ceiling
