Soundproofing
FreeD
Had a customer today who wanted me to soundproof some cavity walls between houses...because of tv noise. I've looked into wall panels + quilts from this company https://www.customaudiodesigns.co.uk/soundproofing.htm all look fairly straight forward to fix. Any1 used any of these products? recommend a supplier? what sort of day rate would you be looking at to fit these products?
cheers
you might be treading on thin ice here mate because theres loads of different systems and if miss poo face turns her telly up really loud the customer might still try blaming you ...........
to put a spanner in the works ive used parge coat.......im not sure if you could use it over old plaster, i used it on new build.......its the equivalent to a coat of s/c and goes on really tight 6mm take this with a pinch of salt ....maybe you could gypbond / parge coat and dab soundcheck boards over the top??????????
Link Removed
this might be of interest to you.... a tv show called room for improvement blah blah they convert a cellar into a soundproof disco and they talk about different sound insulation etc...
first intall 4OD
https://www.channel4.com/4od/index.html
then when it loads up click "TV" near the top
then on the left click "homes"
click the programme "room for improvement"
pat your head and rub your stomache
click "episode 35"
tick the box n click stream now n sign in etc and enjoy Cool
