The Apprentice
Going to give a spat a go for the 1st time this week, never having used one before I would appreciate any helpful advice on how best to use them and when to use them. Thanks
Which one are you using, the are good for nice flat walls and ceilings , I use them after second coat has been speed skimmed and pulled in a bit,great for final trowel, saves the shoulders,Using on skimming
Helpful advise on here fvcking good luck with that one there a bunch of cvnts lol
******* good luck with that one
Looks fine. s*p*r*lex are good for big flat areas.
Only used the trowel to get it on, the rest was done with a supaflex. Guess im just lucky eh :rolleyes)
I find that the eze feels cheaper too, needs more of an ergonomic handleI got an eze on order now to see how it compares, I like the idea of replaceable blades instead of another 50 notes when I drop it
True, fresh plaster always looks good if its flat at all, I find that the spats dig a bit and create hollows.Regardless of the quality of the work in that picture. A distant photo of a skimmed room proves **** all apart from there is plaster on the wall
These we done with s*p*r*lex, so,easy to bend them though,
five forty metre ceilings, really easy job with spat and speedskim.my shoulder needs it easier, I do think its not as good as a trowel start to finish though
The are good for nice flat areas not so good for refurb works, I use them less and less now especially now that we are on quality jobs .If that's the case John then why did you not stop using them after the first ceiling? Ease over quality?
Agreed about the tiger stripes especially with multi, we have changed to board finish and use the Ss and spat less and lessIs it just me then or when you use them they put loads of tigers in them? Nice work gaz always impressive looking at a wall someone's skimmed :RpS_thumbsup:
It seems to have changed I thought that as well, funny with the board finish I always found it saved half an hour a set but on this job we are doing its not that fast but its finishing nicerI've only used it once years ago John, I keep asking our boss to try it but he never bothers multi seems to have gone greasy lately
Selco sell board for 4.19 plusIf you use a lot oilican try ringing travisseeyoucomingpullyourepantsdown in Bristol I'm sure the list price is cheaper than multi
Is it just me then or when you use them they put loads of tigers in them? :RpS_thumbsup:
Clinic ?I think the tigers are caused by not keeping your member
I just scrape it off and keep going
Cheers Danny :rolleyes)I think the tigers are caused by not keeping the blades clean... so the plaster builds up on the edge and then causes the stripes
i think i saw board finish at £4.68 in wickes the other week. Although personally I prefer multi as i can get an extra bag a set a on.Wickes sell board.
