Do speedskim not do those with the stainless steel tip?? I've never rated them infact hated the original one (the grey cavity closer type) bought an eze spat and never looked back. but @scottie5 rates these new blue ones and he knows his onions so to speak and curiosity makes me think I may give them a try?
You prefer the metal tip or blue plastic if you had to choose one?the new speedskim SF is the new metal tipped finishing blade Greg it's very good and very much like the spat just lighter and more comfortable to hold.
the ST blade is the blue plastic blade its a great tool for flattening skim and for the first couple of passes on it , (and also good for closing up backing coats) this blue blade is fantastic it replaced the old grey one but it is so much better then that was.
I really can't see the benefit of a piece of plastic to flatten over
Perhaps I'm missing a trick?
I do like to do a nice big gauge 10-15 sheets is a nice hit.
I might get the speed skim out next time I'm skimming
Give it a go, I was sceptical at first, but I am a convert now. I recently used my 1200 on a ceiling via the pole, got 1st coat really flat, finished it with the 600.I really can't see the benefit of a piece of plastic to flatten over
I assumed it was just used for flattening?
I'm indoors for a few days so I'll give it another go
It's the old style one mind
Anything to help the old bones!!
If it's got the white/grey blade I had one and it wasn't very good
The blue one is just the same pal... bought one to give it a 2nd try and ended up selling it.... yes it does flatten the wall but not as good as the sf or spat.... ànd you can use these alot further into the gauge....I had the one with white/grey blade and it wasn't very good
Liked
Never used a speedskim but use a spat, so would be interesred in trying a metal bladed one.
whats the better size 600 or 1200 ?
Can the blades be changed / replaced ?
600 is all I use if that's of any help, 1.2 to big imo anyway but life is full of choices.Never used a speedskim but use a spat, so would be interesred in trying a metal bladed one.
