Fuk knows and no intention of finding out . Seen it done by loads of youngens but I just stick to the traditional way I was taught as kid . Some lads rate it but I've never bothered tbh each to there own I guessCan anyone offer some tips?
When do you sponge it do you let it go and sponge a small amount and go straight over it or get on it a bit earlier and let it pick up etc etc x
If you catch it right it leaves a lovely finish its just the catching it right but that’s tricky
I use one on sovereign finish plaster, use it after I've flattened the second coat after it's picked up a bit.Can anyone offer some tips?
Thanks bob that’s what I do but get a few sponge lines don’t know if I should be leaving it later, sponge a smaller amount and get on it straight away, 10m a time sort of stuffFlatten off
Around the same sort of time you'd flick to wet trowel, maybe a tad earlier depending what your going over, also differs if you're one or two coating.
Also - I really appreciate the kiss.
Means a lot
X
I've not found a sponge I like, but have used a carpet float plenty of times.Can anyone offer some tips?
Two coats on, let it pick up beyond the point you'd give it a first trowel and then whizz over it with the float and then drop back and trowel it up.
Sometimes I'll float a couple of walls or more before dropping back to trowel them.
I definitely wouldn't be using this as a preferred method, it's more of a get out of jail free card for when it's cold and/or damp, or you've got one of those particularly dreadful batches of plaster.
Done properly the work will come out absolutely mint.
Always happy to help a newcomer to the trade Dave.
lol you know the difference between me and you?sponge floating skim never heard so much bollox in my life....on same par with those idiots who use wonderstuff pink SBR on a re-skim as well, trades been turned into a laughing stock by clueless chancers as well as 2 minute thicktokkers and 5 min facefucking ego tossers
I tried the fine bob for me it seemed a better finish may be a fluke who knows, there harder to use though they don’t glide like the medium onesRefina 'Medium' orange are about right for me.
Their 'coarse' orange also works, but it's a bit strong for me.
I probably only use these at most 3 or 4 times a year if I'm honest.
So I clean them really well and pick all the shite out first before putting away.
Evening @Lurpy!sponge floating skim never heard so much bollox in my life....on same par with those idiots who use wonderstuff pink SBR on a re-skim as well, trades been turned into a laughing stock by clueless chancers as well as 2 minute thicktokkers and 5 min facefucking ego tossers
Well said but yiur still a cooont . Ha hasponge floating skim never heard so much bollox in my life....on same par with those idiots who use wonderstuff pink SBR on a re-skim as well, trades been turned into a laughing stock by clueless chancers as well as 2 minute thicktokkers and 5 min facefucking ego tossers
