bprenderingservicesltd
has anyone ever sprayed mortar coat for brick effect or would be too much of a fanny on with you forming corners ny hand
thats something i wanna try... brick.effectOnly way ive ever done it mate done loads in the past ewi.got one to price up it was just a thought to see if anyone had done it this way.,obviously not the brick coat just the base
Yeah a thought that but its just ive never known anyone do it this way,a think it would work on gables fine not so sure bout it with loads of windows and a door to deal withBe just like spraying basecoat maybe???
same as a texturing day...keep well clear of that one, it is a dirty job you will go home looking like a red I****n !
If you are using K Rend the spec says you can spray both coats , I guess it depends on the amount of area you are spraying and how you manage it.has anyone ever sprayed mortar coat for brick effect or would be too much of a fanny on with you forming corners ny hand
