steel lintel (I shape)
Re: stel lintel (i shape)
If its 'I' shaped as you say, whack a few wooden noggins into the I section nice and tight and then just screw into them for the sides, and a liberal amount of dri-wall adhesive for the underneath chief
Nog it out then fix a slate batten or 2x1 along the length then you wont have to fix adhesive to the steel, board round it..
i stick with gripfill. gotta be aware tho, theres rules and regs about rsj's but i don't know what they are :-[
ON A SLIGHTLY MORE SERIOUS NOTE DO YOU HAVE TO DOUBLE BOARD FIRECHECK AROUND THE WHOLE RSJ OR JUST THE BOTTOM ............ERR BIT
Nog the steel out then measure the depth, width , depth score your plaster board one side and just wrap it round the steel no need to worry about fixing the soffit once its beaded it aint going nowhere.
Lucius
