OceanWave7
I recently had plastering work done in my hallway, landing, and staircase. Additionally, some new boards were required for a stud wall in the hallway. While the finish looked largely acceptable, there are specific areas that are unsatisfactory to me.
The images don't capture everything, but for the most part, I've noticed some dings (likely from the plasterer's trowel), some uneven spots that would require filling and sanding prior to painting, and neglected spots near an electrical socket and a switch.
For the job, I was charged over £1250, and this was carried out in the Midlands. The work entailed a day of prep with two people and another day for applying two coats of plaster, also by two people.
After noting these issues, the plasterer returned and filled some of these imperfections with fine surface polyfilla (still missed some) and said that these should be sanded down by the decorator before the mist coat is applied.
Is it reasonable for me to be unhappy with this outcome and the proposed resolution from the plasterer?
Also, after a skim coat should it be completely smooth from top to bottom, including just above the skirting? As currently that's all completely rough...
