BryantPlastering
Hi All
Who would be the best person to ask about advice on rendering a pool?
130m2 to do in s&c with sbr. 10mm thick then tiled.
Only ever done small ponds and bits subbed the bigger ones out in the past,so little out of my depth .... no pun intended.
Mix ratios ,? Cure timings? Plum & dot then rule?
Systems and sequencing of works appreciated.
Thanks in advance.
Thanks in advance.
