S
spunkybum
Guest
does anyone need a hand? i'll work for nothing but i'll probably do youre head right in .........failing that can anyone recomend any decent courses?
how quick do you want it to be? a set of skimming using multi finish with 2 coats takes three hours? not quick enough?mowdo said:hi guys any one used universal one coat? need to go over artex in a hurry
You'll use more gear by hand jointing, and the first coat (joint filler/fast set) is normally done by hand anyway. Hand applying is slower, that's all. If the boarding is bad, then you may need to finish some joints by hand to feather them out wider than the 12" box finish. The internal finishing equipment is what is going to save you the most time too.spunkybum said:tony i was chatting to a jointer today and he said forget the courses there rubbish cause they wont teach you how to get over problems .....which is fair enough ???....(bit of a knob though so is he lying?).......he's using a machine mate (french word) me i know what you mean he's got one for putting the tape up in the corners ...how much was that mate ........about a grand ...then another for putting the mud on like a twitcher with a box on it and i was rubbing my fingers over it (he'll hate me in the morning ) and it was absolutely perfect !.........is the hand applying trickier ?..........thanx mate if i can make it where are you cornwall? that would be sound can we play it by ear ....
grand wizard said:tone you ever stuck youre internals with unibond
spunkybum said:we are working for a firm that do more tape jointing than plastering and are a sound bunch of lads so i can practice on their jobs and hopefully they wont kick me off ;D............tbh its need must mate theres bugger all out there at the min
