Tc render straight over sand & cement ?
Stanbra
Heard you can apply primer then go straight over normal sand and cement render but just don't get the guarantee you would get from using the correct base coat. I was told you could go over painted surfaces with tc render awel.
ive chucked tc over old sand cement plenty of.times.... primer and coat.
but with painted surface i put a tight coat of base over it 1st
In my early days when people wouldn’t pay for the modern base coats I did loads of sand and cement with Jub primer and silicone.
Still there today. But you will need more primer than usual.
What t.c . render , top cat
Did a few hundred metres over paint about 6-7 years ago, right next to the sea and gets battered . Still looks sound. If we do go over paint we use a strong wire attachment on a 4" grinder. Gets rid of any loose paint.
