The cold temps are almost upon us - Don't forget the basics!
Plasterers1StopShop
It's the simple things that are often the most easily forgot - yet the most important!
Here is our winter warning to all machines users:
With the cold temperatures now coming in, it's very important to drain all water from your machines after use.
Ensure all valves and taps are open - even blow through your pipes to be 100% sure no water is left within the Flow Tube or water pump!
With the water freezing overnight it can cause your flow tube to crack, or even damage your water pump!
Keep on top of the simple things and keep working!
Mrs blows my pipe throughout the year regularly :sisi: so no issues here:whistle:
