Therma Render?
Jonjo
Hi,
I posted re rendering the outside of my house.
I'm still looking at different options and would appreciate any opinions on Therma Render.
Anyone had any experience with this?
Thanks,
Jonjo
It does exactly what it says on the tin it insulates you're house and comes with a variety of finishes, it's the most expensive another option is too insulate you're cavity and render it normally
It was just to really get away from having to paint every few years and it has more of a plastic finish. I was just worried Therma Render would need the same upkeep as K-Rend. Do ou know if this is the case?
Its a pain my house having render on but it needs re rendering so it's got to be done. Just want the simplest option
Jonjo
An acrylic finish isn't pitted like mono so all the s**t doesn't gather in the texture it's a really fine stipple and you dont have to insulate youre house to get the finish insulated render is at least a third more expensive than the other option but then you would still have to pay out to get the cavitys filled etc where are you based theres loads of different ways to render a house and different options
Also whats you're budget if you work out the money you've got devided by the amount of metres that will give us a square metre rate lads will be able to tell you straight away what system you can afford
