More peopleHow do you guys manage laying on big areas with a silicone finish and keep at wet edge??
Any tricks ?
Cheers
Yeh I got no friends
Spray itHow do you guys manage laying on big areas with a silicone finish and keep at wet edge??
Any tricks ?
Cheers
Stay in front of the sun on each elevation, 4 ft drops, float up your joins on each drop first and go like f**k,How do you guys manage laying on big areas with a silicone finish and keep at wet edge??
Any tricks ?
Cheers
@ by hand 2 laying on /one followingHow do you guys manage laying on big areas with a silicone finish and keep at wet edge??
Any tricks ?
Cheers
correct .
Yeh thought so although not to keen on the spray finish …. Can you spray then flatten off?Spray it
Yes you can it does look better too but I just spray it the 1mm grad looks better sprayed than 1.5mmYeh thought so although not to keen on the spray finish …. Can you spray then flatten off?
