Render Systems
Hi thin coat is exactly what it is but has a couple of exceptions on varying backgrounds.
the top coat is allways put on as thick as the grit size in the mix and no thicker as it will not finish properly
on cement board or lafarge aquatech you first apply your base coat to 3mm maximum then embed TV10 mesh into this allowing a 150mm overlap on the mesh, at ground floor level a heavy duty panzer mesh is usually employed.
get this coat as flat as possible as any marks will show through the top coat
you may then have to colourprime this base coat if its not the same colour as the finish (basically paint the base coat)
if you have any lines in the base use a carbarundum stone to take these out the following day.
when applying the top coat work as fast as possible always keeping a wet edge and if more than 1 person is finishing the top coat rub up in same directions ie both clockwise or both anti clockwise as if you do it different directions it will stick out like a sore thumb.
follow the above over EPS making sure you rasp the eps flat before applying the base coat
